Ansys Learning Forum Forums Installation and Licensing Ansys Products Missing Fluid Flow (Fluent) from Ansys 2023 Workbench toolbox Reply To: Missing Fluid Flow (Fluent) from Ansys 2023 Workbench toolbox
Rajeshwari Jadhav
Hi Dana,
Please add these entries to your C:\Program Files\Ansys Inc\Shared Files\Licensing\ansyslmd.ini file?
 ANSYSLI_FNP_IP_ENV=1
ANSYSLI_TIMEOUT_FLEXLM=20
ANSYSLI_FLEXLM_TIMEOUT_ENV=20000000
ANSYSCL_TIMEOUT_CONNECT=60
ANSYSCL_TIMEOUT_RESPONSE=300
  • Also, set the following Environment Variable –
Go to START > ‘Edit the System Environment Variables’ > click Environment Variables.
Under the System Variables, please click NEW and create a new variable.
Variable Name – FLEXLM_TIMEOUT
Variable Value – 50000000
Save it.
  • Config File Reset -
Now open a file explorer and type %appdata% in the address bar.
Locate the Ansys folder and rename it to Ansys.old.
Relaunch the application.
  • If still issue still persists, check if firewall exceptions are added on the server end.
In case you are running Windows firewall, let’s try to add a firewall exception in the license server:
1.      Start à Search for Control panel à System and security à Windows firewall defender.
2.      Click on  “Allow an app or feature through Windows Firewall Defender”. It must be at the top left.
3.      Click on “Allow another app” à Click on “Browse”.
4.      Then browse through “C:\Program Files\ANSYS Inc\Shared Files\Licensing\winx64” and select “ansysli_client” or “ansysli_client.exe” à Click Open à Click “Add” to confirm.
Follow steps 1 to 4 and add these 5 exceptions:
§  lmgrd.exe
§  ansyslmd.exe
§  ansysli_server.exe
§  ansysli_monitor.exe
§  ansysli_client.exe
