Ansys Learning Forum Forums Installation and Licensing Ansys Free Student Software The FLUENT application failed to validate the connection Error Reply To: The FLUENT application failed to validate the connection Error
Federico
Hello James,
Can you try the following?
Close all the Ansys applications.
Go to Start>search “Product and CAD Configuration 2023 R1” and run it as admin.
Follow the below steps: (while configuring products and unconfiguring products “select all” option)
  1. Install Required Prerequisites.
  2. Unconfigure Products & CADs.
  3. Configure Products & CADs.
Rename the Ansys folder to Ansys.old (search %appdata% in Windows File Explorer search bar) and .ansys to .ansys.old (%temp%)
Launch the application again.
Let me know if the above solutions work for you.
