Ansys Learning Forum Forums Discuss Simulation Fluids Negative cell volume occuring when using a quarter model Reply To: Negative cell volume occuring when using a quarter model
C N
Hello Loics,
Is there any interfaces you created for the problem? If not step 1 is not required.
Executing TUI command please go to console and type the command which I have mentioned within the brackets. - step 2
Go to the spaceclaim and perfrom geometry repair
Check for any issues . Then
Import it to fluent - check for any mesh overlap at the edges - this can be done going to mesh display option and zoom the object at edges woth the mesh to find out.
This is how you can perform these steps.
Thanks,
Chaitanya Natraj
