Ansys Learning Forum › Forums › Discuss Simulation › Fluids › find out the chamber is vacuum or not › Reply To: find out the chamber is vacuum or not
SRP
When you import CAD/Mesh in fluent, it is just a solid model nothing is there in fluent. Fluent is a platform where you create a required environment that you want to simulate. Environment is created by specific boundary condition and giving the initial conditions in fluent. Initialization is a command which helps to set the initial condition for your problem.
Hope this clears your doubt.
Thank you.
