Ansys Learning Forum Forums Discuss Simulation General Mechanical Problem with mechanism, spherical joint out of the body Reply To: Problem with mechanism, spherical joint out of the body
Germán Ferrando
Hi Peter, thanks for your answer, i tried but it happened the same issue, i also tried replacing the revolute joint with a bearing but then it doesnt keep contact with the big part. I have surpressed all the parts that arent the mechanism and the right transient structural is the one named final project.
https://drive.google.com/file/d/1lAOetEZLWw3OQzT7ECEIbwumt4ykUkOa/view?usp=drive_link
