Ansys Learning Forum Forums Discuss Simulation General Mechanical Unable to use element birth and death for REINF 264 or 265 elements Reply To: Unable to use element birth and death for REINF 264 or 265 elements
mer153
Hi Dave,
I am glad you confirmed it should work, but the problem is that it doesn’t. I can share an example case with you through the ANSYS Customer portal to see the problem. I'm worried that this might be a bug.
