Ansys Learning Forum Forums Discuss Simulation Photonics temperature sensor simulation in Lumerical Reply To: temperature sensor simulation in Lumerical
Guilin Sun
Please follow the steps in the example and if you have questions to a specific step please write a new post for each question.
If you read the intruction you will notice that the FDE model has built-in index change with temerature, which is the 2nd method I suggested previously:
You can change this model, or use HEAT simulation.
