Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › MEMS and Lorentz forces › Reply To: MEMS and Lorentz forces
J G
HI Bill,
I am new to Ansys and was trying to replicate the simulation above.
The simulation setup is almost identical to what you have done above.
I assigned both the bodies with same material (structural steel, the Command object should overwrite the properties for the air) and had one Physics region assigned for all the bodies.
Apart from that, everything else is identical to your setup above, but I kept getting the errror below (i have copied the whole solution information at the end).
 *** ERROR ***                           CP =       2.531   TIME= 22:06:58
 For element type = 2 (SOLID226), KEYOPT(4) = 4 is invalid.
Which I feel shouln’t be case as I can see the option in valid in the table from the element reference document.
Is there something else I am missing?
 Verification–Coupled Field Static (A5)
          ***** MAPDL ANALYSIS DEFINITION (PREP7) *****
 *********** Nodes for the whole assembly ***********
 *********** Elements for Body 1 “beam” ***********
 *********** Elements for Body 2 “air” ***********
 *********** Send User Defined Coordinate System(s) ***********
 *********** Set Reference Temperature ***********
 *********** Send Materials ***********
 PRINTOUT RESUMED BY /GOP
 C*** Beam attributes
 *GET  DMNSN     FROM  PARM  typeids   ITEM=DIM  1     VALUE=  1.00000000
 *IF  dmnsn                             ( =   1.00000     )  EQ
      1                                 ( =   1.00000     )  THEN
 ELEMENT TYPE       1 IS SOLID226     3-D 20-NODE STRUC-EMAG SOLID
  KEYOPT( 1- 6)=    10101      0      0        0      0      0
  KEYOPT( 7-12)=        0      0      0        0      0      0
  KEYOPT(13-18)=        0      0      0        0      0      0
 CURRENT NODAL DOF SET IS  UX    UY    UZ    AZ    TEMP  VOLT
  THREE-DIMENSIONAL MODEL
  KEYOPT( 7-12)=        0      1      0        0      0      0
 *ELSEIF  dmnsn                             ( =   1.00000     )  EQ
          2                                 ( =   2.00000     )  THEN
 *ENDIF
 MATERIAL          1     MURX =   1.000000
 ARRAY PARAMETER MATIDS    DELETED.
 ARRAY PARAMETER TYPEIDS   DELETED.
 SET PARAMETER DIMENSIONS ON  MATIDS TYPE=ARRA  DIMENSIONS=     1     1     1
 PARAMETER MATIDS(1) =     2.000000000
 PARAMETER MATID =     2.000000000
 SET PARAMETER DIMENSIONS ON  TYPEIDS TYPE=ARRA  DIMENSIONS=     1     1     1
 PARAMETER TYPEIDS(1) =     2.000000000
 PARAMETER ARG1 =     1.000000000
 C*** Air attributes
 ELEMENT TYPE       2 IS SOLID226     3-D 20-NODE COUPL-FLD SOLID
  KEYOPT( 1- 6)=      111      0      0        0      0      0
 NUMBER OF WARNING MESSAGES ENCOUNTERED=          0
 NUMBER OF ERROR   MESSAGES ENCOUNTERED=          1
 ***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****
Jack
