Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Limiting deformation upto a value › Reply To: Limiting deformation upto a value
peteroznewman
Hi Hakim,
Have you already pulled on the front face of the block and observed > 5 mm directional deformation of the sides of the box?  If you got less than 5 mm then you can skip modeling anything inside the box!
