Ansys Learning Forum Forums Discuss Simulation Materials [Material Designer] Homogenized Properties of a Sheet? Reply To: [Material Designer] Homogenized Properties of a Sheet?
John Doyle
The Material Designer Docs do not list corrugated sheet as an RVE model type option, in particular.  However, there is a "honeycomb" option - described as consisting of cells with hexagonal shape repeated in two dimensions.  Would that work?  See Section 2.1.8 of the Material Designer User's Guide.
