Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Is there a way to calculate the grinding consumption through FLUENT › Reply To: Is there a way to calculate the grinding consumption through FLUENT
You can check their position. There's also the erosion and accretion model(s), but they're designed for impact effects rather than grinding. However, if it's a high volume fraction of solids DPM isn't appropriate.
