Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Opening ICEM with MATLAB › Reply To: Opening ICEM with MATLAB
Essence
"I would suppose this terminal is what ICEM uses to perform commands." This might be the issue because, while importing the geometry, the working lines and points get selected when starting the ICEM.
Could you try to select them using Matlab?
