Ansys Learning Forum Forums Discuss Simulation Fluids Divergence happens when only geometry is changed Reply To: Divergence happens when only geometry is changed
mechE
Hi Weiqiang Liu,
Can you please explain what is step by step convergence strategy?
I am facing a similar problem. My simulation works for 1.5 mm diameter but there is divergence after few iterations when I reduce the diameter to 1.1 mm and 0.9 mm.
