Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Using Lumerical hpc licenses › Reply To: Using Lumerical hpc licenses
@Ruzan,Â
Academic licenses does not work with Ansys HPC licenses. The HPC license is only available for commercial/enterprise licenses.
Based on your current entitlement/licenses, you should be able to run a single simulation up to 1280 processes/cores. The simulation/project and the machine running the simulation will affect the performance. You can increase the number of processes/cores used to the run the simulation up to a point that increasing the number of processes/cores will not improve the performance.Â
We have the following KB that might help:
FDTD Performance Benchmarks – Ansys OpticsÂ
Determining the optimum resources to run FDTD – Ansys Optics
