Ansys Learning Forum Forums Installation and Licensing Ansys Products Discrete Phase Model Settings (Steady State) Reply To: Discrete Phase Model Settings (Steady State)
Andrew Roberts
Thanks for your reply. As far as I understand it, this is assuming a steady state condition (because unsteady is not checked).
If it is checking like Courant Number: what is the timestep that would be used? (is this set to unity) - I couldn't find the answer in the guides. So the particle is checked N times (step length factor) according to the ratio of the cell velocity and cell size only?
