Ansys Learning Forum Forums Installation and Licensing Ansys Products ANSYS-RSM Job will not run on the cluster error message Reply To: ANSYS-RSM Job will not run on the cluster error message
VJ
Hello, is the compute node and your submission workstation on the same network?
If yes, can you ping the headnode from your workstation?
Does the test job from the RSM Configuration run successfully? if not, can you please copy and paste the RSM job report?
