Ansys Learning Forum Forums Installation and Licensing Ansys Products Missing Fluid Flow (Fluent) from Ansys 2023 Workbench toolbox Reply To: Missing Fluid Flow (Fluent) from Ansys 2023 Workbench toolbox
Rajeshwari Jadhav
Hi Dana,
Can you please try the below options:
  1. Can you close all Ansys applications, then go to “C:\Users\user_name\AppData\Roaming” or type %appdata% in the address bar and rename the “Ansys” folder to “Ansys. old”?
    • Once done, relaunch the application and check if the required extensions are visible.
  1. Can you try to “reset workbench” from the view option?
Let me know if this works for you.
