Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Is there a way to calculate the grinding consumption through FLUENT › Reply To: Is there a way to calculate the grinding consumption through FLUENT
You'd be using not setting the value. It depends on what correlation you have and want to use. I can't help you with the what, that's for your literature review to figure out.
