Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Is there a way to calculate the grinding consumption through FLUENT › Reply To: Is there a way to calculate the grinding consumption through FLUENT
July 11, 2023 at 9:16 am
Linking shear to grinding? You need a correlation and you can then use a Custom Field Function (or UDF) to plot the value of the supplied correlation.Â
