Ansys Learning Forum › Forums › Discuss Simulation › Fluids › parabolic velocity profile causes reversed flow › Reply To: parabolic velocity profile causes reversed flow
My point is it's possible you added a negative in somewhere by accident. The other check is position: is the inlet centre at y = z = 0 ?   Please post the code, if it's an easy fix I'll tell you.
