Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › File extension types and uses › Reply To: File extension types and uses
Sampat Kumar
Hi
.dat file – The .dat file in ANSYS contains the instructions and parameters to perform a simulation. it acts as a command file that the solver reads and interprets to carry out the simulation. You can use the.dat file to know the command.
.cdb file- cdb is a coded database file. includes preprocessing, boundary conditions, analysis settings, etc. no results are included in this file. it can be read into APDL and External Modal.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/ans_prog/Hlp_P_INT3_3.html
Sampat
