Ansys Learning Forum › Forums › Discuss Simulation › Fluids › negative absolute pressure in multiphase flow › Reply To: negative absolute pressure in multiphase flow
July 11, 2023 at 6:11 am
Thanks for reply.
Yes! The default value of Fevp is 50. However, This needs to be reduced to have a better match between experimental data ( mass flow , pressure profile, and vapor fraction).
Incorrect values of evaporation and condensation coefficients also resulted in a divereged solution.
