Ansys Learning Forum Forums Discuss Simulation Fluids Convergence issue in Supersonic Simulation Reply To: Convergence issue in Supersonic Simulation
Essence
Select High Order Term Relaxation in Methods. Reduce the Courant number to 2.75 for initial iterations. Reduce the URFs to 0.5 (k and omega). Disable the Compressibility effects in k-w SST and try running. Also, let me know the net mass flow rate, net heat transfer rate and apply a variable report definition to judge the convergence. Use Green-Gauss node based gradient.
