Ansys Learning Forum Forums Discuss Simulation Fluids parabolic velocity profile causes reversed flow Reply To: parabolic velocity profile causes reversed flow
Don't use outflow, it's an obsolete option and really should be removed from the GUI. Pressure outlet is the correct choice.
Best guess with the reverse flow is you got a negative in the wrong place in the Expression or UDF. If you initialise from the inlet which way do the velocity vectors point?Â
