Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Transonic flow (0.4<= mach number <= 1.4) around a circular and square cylinder › Reply To: Transonic flow (0.4<= mach number <= 1.4) around a circular and square cylinder
			July 10, 2023 at 1:53 pm
	Do you mean plotting? If you're referring to contours etc please review the tutorials. CFD Post was the post processing tool of choice for a few releases but Fluent's built in tools have seen significant improvements over the last several releases.Â
I'd use the xy plots that are needed to answer whatever it was I was investigating. That's one to ask your supervisor as I have no idea what they'll be marking you on.Â
