Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Viewing element results › Reply To: Viewing element results
dlooman
The message only refers to stress results.  The stiffness of the lamina not changing with reinforcement is apparently due to some other model issue.  For example, if the reinforcement is at the mid-fiber location it wouldn't increase the bending stiffness.  Technology Showcase Example 9 uses reinforcing.
