Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › SYS/Surface not wanted? › Reply To: SYS/Surface not wanted?
July 10, 2023 at 7:57 am
Akshay Maniyar
Hi Adrian,
Can you insert a screenshot of your original geometry from SC and explain what exactly you wanted to do? It will help to under your question in a better way and help you more effectively. I guess when you did detach in SpaceClaim it detached all the surfaces of the solid body.Â
If you want to learn SC, you can check the below courses.
Ansys SpaceClaim - Tools Tutorial - ANSYS Innovation Courses
Advanced SpaceClaim Modeling - ANSYS Innovation Courses
Solid Modeling With Ansys SpaceClaim | Ansys Courses
Thank you,
Akshay Maniyar
