Ansys Learning Forum Forums Discuss Simulation Fluids Problem in Fluent, temperature destribution of solar collector Reply To: Problem in Fluent, temperature destribution of solar collector
Essence
You can use Custom Field Functions/ Named Expressions to verify if the flow is turbulent or not. Based on that, you can choose the models.
Please refine the mesh apart from the fluid zones. Please share the screenshot of the models you used (turbulence and radiation).
