Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Divergent hourglassing model near bolt holes using Cohesive zone material › Reply To: Divergent hourglassing model near bolt holes using Cohesive zone material
John Doyle
If the results are not already saved to the rst file, then yes, you need to re-solve.  If you are still having troubles, try it on a simple test model that runs fast.
