Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Directly save the response of a node using LS-PrePost › Reply To: Directly save the response of a node using LS-PrePost
July 7, 2023 at 12:09 pm
Hi,Â
try using the database_history_node (id, set)
in smp run it outputs nodeout which has following header with time stampÂ
 nodal point  x-disp   y-disp    z-disp    x-vel    y-vel    z-vel    x-accl    y-accl    z-accl    x-coor    y-coor    z-coor
in mpp run it will be output in binout you can also check the elout databaseÂ
cheers, ramÂ
