Ansys Learning Forum Forums Discuss Simulation General Mechanical Divergent hourglassing model near bolt holes using Cohesive zone material Reply To: Divergent hourglassing model near bolt holes using Cohesive zone material
wancheng gao
Hello John,
Thank you for your great help!
I added four command objects under the contacts of interest and name them different cid, as "cid3, cid4, cid7, cid8", respectively.
Then i found out the APDL command to output fracture energies in solution section cannot be directly excecuted. So my understanding is  I must solve the model again to output the required energies, it that right? The figure of the setup is shown below.
Kind regards,
