Ansys Learning Forum Forums Discuss Simulation General Mechanical Help needed! – Deactivating remote displacement BC Reply To: Help needed! – Deactivating remote displacement BC
Pritish Sadhale
Hello Gary,
Thank you for your reply. Please see the details as follows.
............... Original setup (Base case which is used as a restart)
.............Load case setup (Case where one of the remote displacements are to be deactivated after 2nd loadstep)
..... Remote displacement is deactivated for UY after 2nd loadstep.
I also tried deactivating all DOFs for that remote displacement, but the result does not change.
Thank you,
Pritish
