Ansys Learning Forum Forums Discuss Simulation LS Dyna Using linear solution method for explicit solver in LS-DYNA Reply To: Using linear solution method for explicit solver in LS-DYNA
Jim Day
There's no switch to make the explicit solver linear in the same sense that implicit can be made linear. Explicit always considers finite displacements and rotations. That said, if the material is *MAT_ELASTIC and there is no contact and the deformation is small, the explicit solution should agree with a linear implicit solution. I would recommend double precision however.
