Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › MSMD battery model › Reply To: MSMD battery model
July 6, 2023 at 12:45 pm
Hi, I am facing the same warning and I am not sure what the cause is. When I plot the curves, the curves that Ansys shows a warning for, have no fit. It only shows the experimental points. This is true with both LM and JH methods. It should be noted that the number of curves the fitting fails for is higher with JH method.
Where you able to find the solution to this issue? Any advice is appreciated. Thank you!
