Ansys Learning Forum Forums Discuss Simulation Fluids How to input a periodic excitation to a flow or jet Reply To: How to input a periodic excitation to a flow or jet
Kauê Castro
Hey Rob, as you previously asked, the velocity contours map:
As you can see, a recurring problem I'm having is the reversing of the flow on the BC (using outflow), one solution I was thinking of is making the second derivative 0 for the cross-stream directions, however I didn't find where I could change that, in the case it's possible.
