Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How to setup a stable sand layer by using Eulerian granular multiphase › Reply To: How to setup a stable sand layer by using Eulerian granular multiphase
Mepal
Thank you for your suggestion,
Did you mean monitering the result by using volume integrals?
Before calculating with a steady, the granular mass is 0.064 kg.
Then after 7,000 iteration, the granular mass reduced to be 2.51e-5 kg.
Does it mean the granular mass vanish after iterations?
