Ansys Learning Forum › Forums › Discuss Simulation › Fluids › a question about porous › Reply To: a question about porous
July 6, 2023 at 8:29 am
If you check the mass flow on each channel are they the same? If you plot static pressure on the same plane I suspect it'll help you understand.
