Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Moving heat flux welding simulation › Reply To: Moving heat flux welding simulation
Sampat Kumar
Hi
Have you verified your input power and the heat flux you provided in the moving heat source? First I would suggest checking the unit and power-to-heat flux conversion calculation. How much temperature you are expecting?
verify these points.
1. Conversion of power to heat Flux calculation and the unit.
2. Velocity and the unit
Sampat
