Ansys Learning Forum Forums Discuss Simulation 3D Design Driving parameter and script parameter Reply To: Driving parameter and script parameter
mjmiddle
I don't see a problem here.
A parameter made during the Move tool is a driving parameter as well as the script parameters. So you will have 3 driving parameters. But it is not good practice to make parameters with the native tools such as Move tool and also use script parameters. There may be an unintended result depending on which parameter is updated first. It is better to record the Move tool as script commands, and make another script parameter to use in that code.
Driving parameters can be tagged as optimization parameters in DX. I don't use OptiSlang, but it probably can use the same driving parameters as optimization parameters.
