Ansys Learning Forum › Forums › Discuss Simulation › Fluids › outlet type in boundary conditions › Reply To: outlet type in boundary conditions
peppers
However, when using the "pressure-outlet" boundary condition, you need to input data such as pressure and back flow temperature. In my case, I only have velocity data, and I am trying to find the temperature at the outlet. If I input a value for the back flow temperature, let's say 300K, the outlet temperature becomes 300K. Is there a solution for this?
