Ansys Learning Forum Forums Discuss Simulation General Mechanical Harmonic Analysis Results Reply To: Harmonic Analysis Results
dlooman
Both full and mode-sup harmonic should give non-zero results at 9 hz.  At very low frequencies the result will approach a static solution, but will not be zero. Â
