Ansys Learning Forum Forums Discuss Simulation Fluids How to calculate evaporation and chemical reactions simultaneously Reply To: How to calculate evaporation and chemical reactions simultaneously
Ren
Hello, Shin,
If you wanted to set up the reactions by importing a Chemkin mechanism instead of manually entering the reactions, you can import the mechanism using the following command:
File->Import->CHEMKIN Mechanism...
After this, the mixture material will become available for the phases.
The Chemkin-CFD chemistry solver is not available for multiphase problems.
