Ansys Learning Forum › Forums › Discuss Simulation › Photonics › multiple sources in topology optimization › Reply To: multiple sources in topology optimization
Fakhriyya Mammadova
Thank you Niki,
I am trying to design AND logic gate. I wanted to set both sources for 11 case and set transmission to 1 on the output. However, the transmission I obtain is close to 0. I am not sure why. I used two sources and named them both as 'source' just as you said
