Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Increase the maximum number of equilibrium iterations per solution step in Mechanical › Reply To: Increase the maximum number of equilibrium iterations per solution step in Mechanical
July 5, 2023 at 11:38 am
https://www.ansystips.com/2017/09/increasing-number-of-iteration-per.html
you can refer to the link above to add the Command object with NEQIT,30 in it.Â
