Ansys Learning Forum Forums Discuss Simulation Fluids Pressure difference of two faces Reply To: Pressure difference of two faces
Aniket Chavan
How are you importing pressures? Are you exporting csv files from CFD and then bringing in the data to Structural using external Data
OR directly coupling CFD to Structural?
If the former, you can use a multiplier of (-1) for pressure from one side and then map two csv files on same surface, I believe this should add two different pressures and give you the difference.
-Aniket
