Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › SpaceClaim how to split a fluid domain into 2 › Reply To: SpaceClaim how to split a fluid domain into 2
July 4, 2023 at 7:46 pm
thanks, I did as you described. I found one different point from the geometry created by DesignModeler that in meshing all internal faces, once selected, are green highlighted inwards instead of outwards. Is this the special feature of SpaceClaim that Volume Extract creates a fluid solid rather than a fluid?
