Ansys Learning Forum Forums Discuss Simulation Photonics multiple sources in topology optimization Reply To: multiple sources in topology optimization
Niki Papachristou
Hi Fakhriyya,
Even though lumopt was not built to work with multiple sources there are two ways to achieve your optimization. You can either co-optimize the performance of both inputs separately or can you have two input sources and if you name both ‘source’ the automated routines should work. However, if you provide us with more information on what you are trying to achieve we might be able to give you more guidance.
Niki
