Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Need to calculated Accumulated Strain Energy Density/Volume › Reply To: Need to calculated Accumulated Strain Energy Density/Volume
zubairakhtar.mohd
The problem is I hae consulted the article as you mentioned but in the definition its per unit volume but when i export it i only get the node values. I dont think so that nodes have volumes. Its should be in per element.
Regards
Zubair
