Ansys Learning Forum Forums Discuss Simulation Photonics Lumerical_project_to_setup_script error Reply To: Lumerical_project_to_setup_script error
Amrita Pati
Hi Alexander,
The error seems to be due to queryuserprop script command. Are you providing the name of the single structure/analysis group whose properties you would like returned? Would you be able to share the line of code where you use this command?
Amrita
