Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Eulerian DDPM | Floating Point Exception Error Still Persists › Reply To: Eulerian DDPM | Floating Point Exception Error Still Persists
Prashanth
It is difficult to point to a solution without taking a look at the case. Most of the times, excessive overlap of particles causes the issues. Also, how are you modeling partice-particle interactions? If needed, use a separate particle time step.
